Here is a list of known errors that you can get while connecting with mosquitto_sub. The following indications use -d (–debug) option to get more verbose output.
Consider the following indications.
Firewall in place. If you run mosquitto_sub with -d option (–debug) and get no single
line of output like this:>> mosquitto_sub -d -h node02.myqtthub.com -i myHubxxxxIdMosq -u myHubxxxxIdMosqUsr -P xxxx -t message/topic/to/subscribe -q 2 (command issued, waiting and without showing no input)Then check your connection see if some firewall is blocking 1883/tcp or 8883/tcp.
DNS problem. If you run your mosquitto_sub with -d option (–debug) and there is a DNS
o route gateway problem, you will get something like:>> mosquitto_sub -d -h node02.myqtthub.com -i myHubxxxxIdMosq -u myHubxxxxIdMosqUsr -P xxxx -t message/topic/to/subscribe -q 2 Unable to connect (Lookup error.). -
Missing default route gateway. If you run your mosquitto_sub with -d option (–debug) and without
a default route gateway, you will get the following error:>>> mosquitto_sub -d -h node02.myqtthub.com -i myHubxxxxxxIdMosq -u myHubxxxxxxIdMosqUsr -P xxxxx -t message/topic/to/subscribe -q 2 Error: Network is unreachable -
Wrong clientId, userName or password. If you run your mosquitto_sub with -d option (–debug) and using wrong clientId, userName or password,
you will get:>> mosquitto_sub -d -h node02.myqtthub.com -i myHubxxxxxxIdMosq -u myHubxxxxxxIdMosqUsr -P test1234f -t message/topic/to/subscribe -q 2 Client myHubxxxxxxIdMosq sending CONNECT Client myHubxxxxxxIdMosq received CONNACK (3) Connection Refused: broker unavailable. Client myHubxxxxxxIdMosq sending DISCONNECT -
Output expected. If you run your mosquitto_sub with --debug, you should get the following
if you connect without any issue:>> mosquitto_sub -d -h node02.myqtthub.com -i myHubxxxxIdMosq -u myHubxxxxIdMosqUsr -P xxx -t message/topic/to/subscribe -q 2 Client myHubxxxxxxIdMosq sending CONNECT Client myHubxxxxxxIdMosq received CONNACK (0) Client myHubxxxxxxIdMosq sending SUBSCRIBE (Mid: 1, Topic: message/topic/to/subscribe, QoS: 2) Client myHubxxxxxxIdMosq received SUBACK Subscribed (mid: 1): 2 Client myHubxxxxxxIdMosq sending PINGREQ Client myHubxxxxxxIdMosq received PINGRESP Client myHubxxxxxxIdMosq sending PINGREQ Client myHubxxxxxxIdMosq received PINGRESP
