Here are some recommended steps to connect to your MyQttHub using mqtt component in a Node-RED flow diagram (secure session).
Before continue please create a device if you don’t one by following steps at:
Jot down clientId, userName and password as they will be required by your mqtt-explorer.com solution
2. Adding mqtt-in node in Node-RED
2.1. Search the mqtt-in component for connecting your hub
2.2. Drag it on your flowchart and then double click for configuration:
3. Configuración del broker MQTT:
3.1. By clicking on the component, a configuration window will appear and we will click on edit a new mqtt-broker:
3.2. Edit “conection” tab as follows:
Host: node02.myqtthub.com
Port: 8883
SSL/TLS: Enabled
Cliend ID: Your client ID (as created at your hub)
3.3. Now configure “security” tab with your device hub credentials:
Username: Your username (as created at your hub)
Password: Your password (as created at your hub)
3.4. Save changes and you’re done:
3.5. If everything ok, we will see something like that:
