1. Intro
Core-Admin allows to apply different security and behaviour options associated to webhosting management:
Next article explores how to apply these options grouped together so you can reduce number of service restart, but also help you move your hosting configuration in a consistent manner, only applying service restart when everything is configured as needed.
2. Applying configuration options
Every time you need to configure hosting options, Core-Admin engine applies them and restart service afterwards so services associated to it takes the configuration option.
However, if you apply several options, this process can be slow a heavy, which might affect web service for a longer time.
Knowing this, Core-Admin includes two options that allow:
First, to apply options using Skip service restart: which allows to apply all options quickly, one after another, without doing any restart…
…and then apply only one restart at the end of all configuration by clicking on: Apply options and restart:
3. How to use these options in practise
With these two options, if you need to apply a list of configurations to a particular hosting, set them by checking “Skip service restart”, and when you are ready, click on Apply options and restart button to do a single service restart.
4. Benefits
Using these options to apply additional configurations to hostings, allows:
To reduce to the minimum number of service restarts.
It allows to apply a set of options in a single step without intermediate configuration steps.
It allows to prepare all configurations, leave them ready and configured, waiting for the best moment for restart to make them effective.
