How to isolate a device in a topic related to its clientid?
We need to isolate the device under its own topic i.e: {clientid}/branch/leaf so the device has access only to its own deviceid topic tree?
You have several ways for doing this. In the following link you have several ideas for that:
In essense, you can use Filters [1] to make ensure some devices are the ones that can publish or subscribe. This way you create these device isolated topic tree:
[1] Sending messages to specific MQTT devices
The idea is to create a set of filters like this:
  • Filter for deviceA (or set of devices like A)
  • Filter for deviceB (or set of devices like B)
  • Filter for admin devices (bypass all restrictions)
  • Deny all filter
This way if a device has no match to any filter, will reach last filter (deny all).
It is possible i.e mosquitto to have a filter with wildcard “clientid” (%c) so you create a topic: “%c/#” so it applies to each device that connects. There are wildcards in myqtthub?
#4
We have just published an engine update that allows to configure topic filters using %c and %u replacements,
just like mosquitto, to provide matching to connecting clientId and userName value.
Here you have additional indication:
