Login failure due to blanks in clientId
Hello @Steve_K
Just let you know we have published an update that will help to avoid problems with login attempts introducing whitespace (blanks) at the beginning or end of clientId, userName or password:
>Login Failed (bad username or password) from RemoteAddress=XX ClientId=' info-xxx' : UserName=Some(___) : BAD-USERNAME-OR-PASSWORD
You can check it at engine login page:
https://node02.myqtthub.com
Best Regards.
“Good news” @anon52426133 !!
