In case MySQL does not starts and shows a similar error at your system log /var/log/syslog
>> tail -f /var/log/syslog | grep mysqld
Aug 12 02:53:57 node1 mysqld: InnoDB: Dump of the tablespace extent descriptor: len 40; hex 00000000003a744b0000400026beffffffff000000000001ffffffffffffffffffffffffffffffff; asc :tK @ & ;
Aug 12 02:53:57 node1 mysqld: InnoDB: Serious error! InnoDB is trying to free page 104638
Aug 12 02:53:57 node1 mysqld: InnoDB: though it is already marked as free in the tablespace!
Aug 12 02:53:57 node1 mysqld: InnoDB: The tablespace free space info is corrupt.
Aug 12 02:53:57 node1 mysqld: InnoDB: You may need to dump your InnoDB tables and recreate the whole
Aug 12 02:53:57 node1 mysqld: InnoDB: database!
Aug 12 02:53:57 node1 mysqld: InnoDB: Please refer to
Aug 12 02:53:57 node1 mysqld: InnoDB: http://dev.mysql.com/doc/refman/5.5/en/forcing-innodb-recovery.html -
And problem persists after starting MySQL server adjusting innodb_force_recovery = 4, then it is likely you will have no choice but reimport all databases.
For that, see next.
2. MySQL databases reimport with Core-Admin
Do a full database dump after starting MySQL server with innodb_force_recovery = 4:
>> mysqldump -R --triggers --opt --single-transaction -u root -p --all-databases > /var/backups/mysql-backups/all-databases.txt
NOTE: save this file because it contains all your data
Cleanup all references to mysql database at /var/backups/mysql-backups/all-databases.txt
NOTE: with a text editor, search for “CREATE DATABASE mysql”, mark and search next CREATE DATABASE to remove the portion in between.
IMPORTANT: it is very important to reimport everything but keeping your mysql and performance_schema
(where all your MySQL users and passwords are located). -
Stop MySQL server, core-admin agent (to avoid having it startup up mysql in the middle of the process), postfix and apache2:
>> /etc/init.d/postfix stop
>> /etc/init.d/apache2 stop
>> /etc/init.d/crad-agent stop
>> /etc/init.d/mysql restart -
With MySQL server stopped, remove all databases but “mysql”:
>> rm -rf `ls -d /var/lib/mysql/* | grep -v ‘/var/lib/mysql/mysql’`
Edit your /etc/mysql/my.cnf and comment out recovery line. Also add indication
to do database innodb file separation:# innodb_force_recovery = 4
innodb_file_per_table=1 -
Startup MySQL (it should start without error because it is empty: only mysql and information_schema databases):
>> /etc/init.d/mysql start
Now connect to MySQL as root:
>> mysql --defaults-file=/etc/mysql/debian.cnf
Reimport all databases with:
mysql> . /var/backups/mysql-backups/all-databases.txt
Run upgrade in case log reports:
Aug 12 10:12:33 node1 mysqld: 190812 10:12:33 [ERROR] Native table ‘performance_schema’.‘events_waits_history’ has the wrong structure
Aug 12 10:12:33 node1 mysqld: 190812 10:12:33 [ERROR] Native table ‘performance_schema’.‘events_waits_history_long’ has the wrong structure
Aug 12 10:12:33 node1 mysqld: 190812 10:12:33 [ERROR] Native table ‘performance_schema’.‘setup_consumers’ has the wrong structure>> mysql_upgrade -u root -p
Restart stopped services:
>> /etc/init.d/crad-agent start
>> /etc/init.d/apache2 start
>> /etc/init.d/postfix start
