Trying to connect to my MyQttHub with Reactjs
Hello Everyone, I’m new to MQTT and I woul appreciate any help, this is the code I’m using:
import React, { Component } from 'react';
var mqtt = require('mqtt');
var options={
    clientId:"ID",
    username:"ArdP",
    password:"Password",
    protocolId: "MQTT",
    protocolVersion: 4,
     port : 1883 ,
    clean:true};
    var client = mqtt.connect("mqtt://node02.myqtthub.com/",options)
client.on('connect', () => {
    alert('Connected!');
    console.log('Connected');
class Garage extends Component {
    render() {
        return (
            <div>
                <h1>HEllooo</h1>
            </div>
export default Garage;
I'm getting the following Error: WebSocket connection to 'ws://node02.myqtthub.com:1883/' failed: Connection closed before receiving a handshake response
Thank you.
