How to use SCI Auth -- Simple Client-ID autentication to connecto your MQTT Devices to MyQttHub.com
Table of contents
  1. Intro to SCI Auth
  2. How to enable SCI Auth
  3. Getting SCI Auth Token and how to use SCI Auth
  4. Checking devices connected and show credentials
  5. SCI Auth requirements
  6. Security considerations
SCI Auth allows to configure MyQttHub.com devices to connect by only providing a particular Client-ID. This is an alternative authentication method for those devices that do not support configuring a userName and an password for its client MQTT connection (just Client-ID).
First, click on a existing device:
Then enable SCI y save:
Having a Sci Auth enabled device, click on it and then click on “Get SCI Auth String”:
That will show a message like:
That is, copy SCI Auth string, in this example, SCI-AUTH-22c2b4c4-9425-4266-8c82-0a9c1fbed77a and configure that as your device Client-Id and connect without providing userName or password.
Using a MQTT-Spy, that will be:
4. Checking devices connected and show credentials:
Now, go to https://node02.myqtthub.com/connected/devices and see how your SCI Auth Enabled devices connect:
SCI Auth only works with devices using at least MQTT 3.1.1 which support clientIds bigger than 23 characters.
Please, note SCI Auth is an alternative authentication method that helps supporting devices without userName/password MQTT client authentication support.
It is recommended to use it only for those cases.
Also note that it is strongly recommended to:
  1. Connect using TLS (MQTT TLS) enabled.
  2. If possible, use MyQttHub.com filter by IP function located at:
Publish without Device Registration?
MyQttHub.com new release – 6.7.778 – What’s new in MyQttHub.com
How to create_Broker -- Connecting to MyQttHub.com
MyQttHub and SparkPlug Spec
Is it possible to access /devices/connected from a device which is not the domain admin?
Connecting esp8266 using PubSubClient
Sonoff "mini" with Tasmota 6.5.0 seems to have a problem with MyQttHub
